2006 Edge juice problem
My dad have a 2006 dodge qc lb manual 4x4 with edge juice with attitude. The truck ran perfectly until yesterday. If the juice is plugged he can't stop the engine with the ignition. If he unplug the juice he can like normaly. There's no code. What's the problem?
Thanks for your help
If you have the turbo timer on, and it hits the pre-determined shut off point, (EGT or time) and does not shut off, then there is a resistor that has blown inside the edge module.
I had this same problem, and after 5 new modules, I found out that it was because I have an Air Dog fuel pump... it pulls too much current for the edge to handle.
Call edge, tell them. They should fix it if you are under warranty. If not, it should not be that bad. They are pretty good about fixing crap.
svanni
Sep 6, 2006 05:44 PM
razor6
22
Jan 20, 2006 03:43 PM
