2 Pyros?
Old Sep 17, 2006 | 02:15 PM
wap's Avatar
wap
2 Pyros?
I installed my tst with R49 this weekend and when it came time for the pyro I couldnt really find a good place for the second one as I didnt want to get it too close to the first one on my isspros for fear of crackin the manifold when it got hot. So I put it as close to the heat shield as possible and in the side of the manifold. My first pyro is right in front of #3. For what it is worth they both read identical from what I can tell except the R49 hangs up for a second of two when it gets kinda hot.
My question is, is there any poblem with the placement of my second pyro?
And could I have simply run the wires form my R49 to the pyro for the isspros and had 2 guages runnin off one probe?
10:00 Friday night I couldnt get ahold of anybody to help me out so I just started drillin and tappin and figured it would work or not and I would go from there.
And for what its worth even on 6/5 RP on 1 the TST seems to runn cooler than my quad or mp8.
Thanks for any help.
Old Sep 17, 2006 | 02:42 PM
RamWheelsBy4's Avatar
Should not really be a problem. My two pryos are a little over an inch apart on top of manifold. Had the second one installed for the HOT Juice about a year ago.
This picture is of the AFE, but you can see the two pyros are in close proximity if you look good.
Old Sep 17, 2006 | 03:07 PM
Timinva's Avatar
DTR Advertiser
Mine is run just like Ramwheels. I think you can run both off the same probe, but like the redundency factor of having two probes. Mine run real close temps to each other but the tst probe stays a touch cooler. Tim
Old Sep 17, 2006 | 03:10 PM
StrokeThisCTD's Avatar
as like ramwheels, mine are about an inch apart
Old Sep 17, 2006 | 03:47 PM
wap's Avatar
wap
Thanks fellas, I needed some reasurance.
Tim you are one of the people I tried to call Fri but as usual we couldnt get in touch.
Mine is set up just like Tim and Johns but intead of bein on the top, if you rotated the probe closest to the front about 90 degrees to the side of the manifold that is what it looks like. It isnt as clean of an install as the 2 above but it puts more space between the probes.
Thanks again for the help.
Old Sep 18, 2006 | 05:37 AM
purged981's Avatar
I just got done installing my tst r49 yesterday and I just hooked the tst to my isspro egt wire and it worked fine. Exact numbers.
Old Sep 18, 2006 | 06:12 AM
wap's Avatar
wap
Kinda wish I would have known that about 72 hours ago.
S2CPitts
Jan 3, 2013 04:21 PM
hamilton71801
May 21, 2010 07:57 PM
bradler
Apr 13, 2009 03:43 PM
grdnw523
Dec 15, 2005 09:17 PM
