18x9 wheels w/ 5"backspacing and 35's will they rub?
Old Mar 19, 2008 | 03:52 PM
yelloz28's Avatar
Well I guess we are gonna find out because I already have the tires and I ordered the wheels this morning
Old Mar 19, 2008 | 04:00 PM
jb818's Avatar
ive got 20x10'' wheels 4.5'' backspacing with 305/55r20 toyo's with a 2'' skyjacker lift and clear with no problem. the tires are really only about 33.5'' tall 12.5'' wide but the wheels stick out pretty far. I just adjusted my lower links out a little bit.
Old Mar 19, 2008 | 04:05 PM
06CTDforAU's Avatar
If you just have a leveling kit you will have some rubbing issues with those tires/wheels. Granted, I don't think it will be unbearable but it could be bad at times if you're in a bind. I've got a 3" lift with 35x12.50's on 18x9 wheels with 5" backspacing and I have no rubbing issues. I also have 1" longer control arms though so that alleviates any rubbing. Any wider tire and I would actually rub on the front bumper.
Old Mar 19, 2008 | 06:09 PM
chipmonk's Avatar
1" longer control arms will make a huge difference in clearing.
Old Mar 19, 2008 | 06:11 PM
yelloz28's Avatar
I will probably move to a 35x12.5x18 in the future just got a great deal on a set of the 325/65's and figured I would buy them $250 for 4 isn't bad. Hopefully I can run them for a while without any big hassle. Should be on next week hopefully
Old Mar 19, 2008 | 06:17 PM
ptgarcia's Avatar
With those 1" longer arms are you having any issues with parts interfering under compression? Those arms are a bit long for only 3" of lift.
Old Mar 19, 2008 | 06:22 PM
yelloz28's Avatar
I was thinking of getting some arms too if rubbing is a big issue, but I figured I would be more in the 1/2" to 3/4" Range.
Are you running new top and bottom arms?
I found a guy on ebay that will make them whatever length you want, was wondering if anyone had used them but no one posted up.
https://www.dieseltruckresource.com/...d.php?t=195658
Old Mar 19, 2008 | 07:28 PM
omaharam's Avatar
The tires he's got are 1.4" larger in diameter than your tires and 1" wider.
Old Mar 19, 2008 | 07:32 PM
chipmonk's Avatar
how far do you think 3" of lift would pull the axle back?
Old Mar 19, 2008 | 07:55 PM
yelloz28's Avatar
Originally Posted by BLACK PEARL
I have 18x9 with 5" of back spacing. The rubber is 35 x 12.50 procomp AT XT. Kore Recon HD leveling kit. I have a slight rub on the back inner fender at full lock. Some longer control arms will fix it for me.
Here some pics http://www.turbodieselregister.com/f...o-comp-xt.html
I have a similar setup to this only I will have a little more backspacing and a little wider tire. I'm hoping its gonna be ok.
He actually says in that post that it only rubs on the flare and not on the fender at all, so I guess we will find out
Old Mar 20, 2008 | 08:10 AM
checkster's Avatar
I needed a 4" lift to clear my 325/65/18 ATZ's and 18x9 5"bs. Tire wouldnt even turn half way with a 2" leveling kit
Old Mar 20, 2008 | 08:56 AM
yelloz28's Avatar
Pro Comp doesn't make an 18x9 with 5" back spacing, it only comes in 4.75" for our trucks.
http://www.procomptires.com/pxa6089.html
Old Mar 20, 2008 | 09:45 AM
checkster's Avatar
my pro comp 6089 18x9 are 5" b.s. at least thats what i ordered and what the box said when the UPS man dropped them off.
looks like yer right though, I dont see them listed.
Tom
Old Mar 20, 2008 | 09:50 AM
yelloz28's Avatar
Well not according to their website or any of the others that I could find, they all say -6 offset and 4.75" backspacing. When did you buy them? Maybe they used to make them.
If you look at that link I posted directly from the procomp website it says 4.75"
checkster's Avatar
see my edited repsonse above. got the wheels maybe 2 years ago
