16's on a 05
Old Mar 10, 2009 | 11:57 PM
phantom 309's Avatar
16's on a 05
My friend has a set of 16's that he is willing to give me however im pretty sure that it wont fit because my truck is stock with 17's?
Old Mar 11, 2009 | 12:43 AM
Hamilton713's Avatar
Nope, wont fit. 17's are the smallest we can fit on these things.
Old Mar 11, 2009 | 07:09 AM
heavyboostin's Avatar
you can make them fit by shaving the brake caliper, one of my buddies did that so he could use his welds from his 02
Old Mar 11, 2009 | 09:25 AM
rich's Avatar
why it will lower your gear ratio
Old Mar 11, 2009 | 09:30 AM
cummulator's Avatar
be prepaired for a lot of shavings on you calipers. go with 17's
Old Mar 11, 2009 | 09:45 AM
cquestad's Avatar
there will be zero clearance for balance weight too...
Old Mar 11, 2009 | 12:53 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
change to 01/02 calipers, rotors and brackets and you can do it
Old Mar 11, 2009 | 03:18 PM
03dodgeoffroad1's Avatar
how would it lower the gear ratio if the tires are the same size
and unless the 16s have a huge offset there will be alot of grinding
Old Mar 11, 2009 | 07:40 PM
chw's Avatar
chw
how expensive would it be???
Old Mar 11, 2009 | 08:04 PM
rich's Avatar
how could a 16 be the same size of a 17
Old Mar 11, 2009 | 08:15 PM
they make 33s, 35s, 36s, and 38s are they different outside diameter because they are on a 16 or a 17 inch rim???
Old Mar 11, 2009 | 08:30 PM
molalla1ton's Avatar
I do not think so, but why go to all that trouble? Buy new rims.
Old Mar 11, 2009 | 09:49 PM
Tobin's Avatar
Rim size has nothing to do with your overall ratio, only tire diameter.
Tobin
Old Mar 11, 2009 | 09:54 PM
thats what i was saying
Old Mar 12, 2009 | 01:03 PM
rich's Avatar
Tobin
so your saying a tire that is an inch in diameter is going to be the same size as one an inch larger. the only way i could see that is if you buy a way larger 16 then a 17 and that doesnt seem cost efficent
