12mm studs/bottom tapping?/info.- opinions please
Old Jan 21, 2008 | 02:38 PM
Billm2004's Avatar
Originally Posted by trik396
I found one online. Cost around $25 shipped. If you want I'll look up the info. Easy job, just time consuming and doing 4,5, and 6 puts you in an awkward position laying across the engine. I was sore for a few days afterwards.
Where did you find it, im looking for one.
Old Jan 21, 2008 | 02:42 PM
trik396's Avatar
Here ya go... price has increased... what else is new.
http://www.jlindustrial.com/RML-4584.../product.html#
anyone want mine I'll make ya a smoking deal... only used 26 times exactly...
Plus before I did my studs I spoke with a couple people in the know. Doug (jetpilot) told me of his experiences with the studs. He recommended using more ARP moly lube. They give you a little container with the studs. I bought a pint more and it was needed to lube them adequately. I have alot of the ARP lube left over also...
Old Jan 21, 2008 | 02:45 PM
skynyrd's Avatar
that chart only gives the ranges when you do a tensile test you come out with a curve of the of the stress strain graph on the following page and the ductile properties of the material. but truthfully the load verse elongation is the most important factor in the clamping of the head.
http://web.vtc.edu/mt/nu358spr03/TTe...c23/spec23.htm
these are test i did while in college.
Old Jan 21, 2008 | 02:50 PM
Billm2004's Avatar
Thank trik396!
Old Jan 21, 2008 | 03:00 PM
Billm2004's Avatar
what did you guys use to turn the tap, just a wrench??
Old Jan 21, 2008 | 03:31 PM
5.9Excursion's Avatar
impact gun... j/k
on the back ones, you can probably use a 1/4 drive rachet with a 12 pt socket to fit your tap.
Old Jan 21, 2008 | 03:52 PM
Billm2004's Avatar
Originally Posted by 5.9Excursion
impact gun... j/k
lol! yeah i was thinking impact gun also, but i thought i would just do it by hand to make for extra work! lol
Old Jan 21, 2008 | 04:20 PM
cquestad's Avatar
Till the tap breaks...then your really going to know what extra work means!
I used a tap handle and a wrench for the back ones.
Old Jan 21, 2008 | 05:14 PM
gsdog1's Avatar
Question
I ran across this concept after already sinking the studs in the engine a while back.
How far are you all tapping down? At present, the studs in my truck only have 2 to 3 threads above the nuts after final torque, IIRC.
Thanks!
Old Jan 21, 2008 | 05:20 PM
cquestad's Avatar
It really is just another 2-3 threads...lol.
I am sure it would be fine to NOT do it...but you know what...400 hp was fine...then 500 hp was fine...then 600 hp was fine...and so on.
Might as well do it AS RIGHT AS POSSIBLE the first tiem and never look back.
Its just time...right? ;-)
Old Jan 21, 2008 | 05:22 PM
gsdog1's Avatar
I am with you there!
Old Jan 21, 2008 | 07:07 PM
jmccart's Avatar
Thanx for all the cool info., guys.
Old Jan 21, 2008 | 07:26 PM
homewrecker's Avatar
So, In what order did you remove a factory bolt and install a stud and what torque did you use for the first sequence of the studs before all the factory bolts are removed?
Old Jan 21, 2008 | 10:51 PM
Luvnacumns's Avatar
I agree with Mark overkill is fine overkill on the wallet not so much.. Cq... I am glad you jumped in on this... I definately listen when you speak!!! If I remember Trik didn't you do a write up on this??? I do agree with cquestad if Lmills is running regular then they aren't so bad...
Old Jan 22, 2008 | 12:15 AM
53 willys's Avatar
the ARP 2000's sound like they would work just fine......it's just that little voice in my head keeps saying get the 625's and never worry about it...lol.....I dont know what to do!?!?!?!?!?!?!?!?!?thanks for the input guys........Has lmills ever popped his head gasket with the ARP 2000's??? I looked at his past posts and he did say he popped it once but that was a stud install error...is what he said????If a guy used his truck everyday and popped the HG it could be down for a day or more....just a couple days down time could add up to the cost difference in the two.
