1100* O.K. for extended periods of towing time?
Hello. I just got back from a trip. There is a long flat road w/nothing around. I kept it at about 70 mph in 6th gear. EGT's stayed at about 1100 degrees for like 35-0 minutes. What would you all say is where I should slow down?
Thanx.
Thanx.
It also depends on where the probe is. If it's in the manifold.(pre-turbo) thats fine all day. If it's in the down pipe (post-turbo) you're running hot.
I have pyro's on both sides, & have seen 1250* (pre-turbo) for several miles at a time with no ill effects This will usualy be about 900*-1000* post-turbo.
That would add to 1200...so I am not sure what you are scared of?
Move it to the back...stick in a 100 degree fudge factor (if it is a real gauge and not a Attitude or PMT...then all bets off)...and let er' rip.
The "rear three" being hotter is not always a given. On mine (mine alone that I know of) the front three (#2 in particular) is the hottest by 100* on average. I have three probes in the manifold, I have moved them around in the manifold thinking the probes were different one to another and in fact the probes were pretty much the same and consistently read the front three on my engine as the hot side. Again, my engine alone that I can tell. The point is, do not take anything for granted.
I like the ending of this post.
I had my Smarty turned way down (from my usual level nine to level 7).
Sregor13
34
Mar 8, 2007 10:42 AM
Sregor13
Mar 4, 2007 04:27 PM
spassey
Jan 15, 2003 07:15 PM
