'05 APPS to Throttle Cable Conversion
I am trying to get some info if this can be done. I have a drive-by-wire truck. I am wanting to switch the trans back over to a throttle cable. I have heard there is a kit out there to make this work. Does anybody know of one?
The reason for doing this is for better control over the tranny. As most of you know when you add power to your truck, you don't have to press the pedal down very far to accelerate. Well, that can cause pressure problems in the tranny. Meaning that you will not have as much pressure because the truck doesn't think you are accelerating very hard. I know there is atleast one programmer out there that causes this situation a little bit more than others, but I think they all do it in some way.
So after talking to my tranny builder, we have decided to try to find all the info we need in order to attempt this conversion. Any input you guys have would be awesome.
Thanks
Thanks
The DTT piece can be programmed for different builds and setups and works quite well, as well as manual cable adjustment from my experience. You just hve to work out what you need and talk to DTT about what it is doing. Every truck is a bit different so make some time to dial it in.
I've had my DTT Guy try 3 times and we cant get rid of the 2-3-2 at light throttle (using Smarty Beta 4.4 primarily...doesnt do it on the others, least not nearly as often)....diff spring, Diff Shift Enhancer Settings,.....not a big deal, but can be annoying in heavy traffic.
I am aware of the TS ShiftMaster and the DTT Shift Enhancer. I do not think either of those control line pressure. There is a lot more adjustability and control when using the cable instead of voltage. My tranny guy is the one who started researching this as an end all to the many transmissions I have gone through. My last tranny build has been awesome and isn't showing any signs of failure like my other trannies did.
I am just trying to get the research done so I can have all parts on hand if my tranny kips again.
The DTT shift enhancer does a better job of any controlling the TV pressure than any of the others as it is programmable. As for better control via a cable, I don't see it on comparable power and trans builds. I guess it depends what you are looking for but my DTT box is as good as setting the cable manually and it is easier to set and change on the fly. I would question anybody that claims controlling line pressure is the key and a cable is better. It just don't add up in my experiece.
I can run moderate and wild TQ management on Smarty if I set the DTT box correctly and things work great. If you don't get all the pieces to mesh its a pain in the rear to drive.
rjm022
Nov 13, 2007 05:33 AM
Kirk T
Sep 20, 2006 07:19 AM
hellotbone
Oct 7, 2003 06:54 AM
