04 Electrical issues
Old Jan 25, 2013 | 01:30 AM
Devil Dog 6227's Avatar
Hey guys im having some issues with my 04 it seems that when the temp drops below 50 deg. my truck goes crazy, as soon as i turn the key on the head light come on by themself, while im driving all my dash lights flash on and off my gauges drop to zero for a couple seconds and then come back to the correct position yet the truck performance remains flawless. but like today it was in the 70's and i didnt have a single problem, has anyone ever run in to this issue or have any ideas
Old Jan 25, 2013 | 09:20 AM
AggieJustin's Avatar
Based on the temperature, I'd venture a guess that there is either something not wired up correctly with your grid heaters, or the grids themselves have an issue. I can't think of what specifically would fail on the grid heater itself since they're basically just an electric heater.
You could try disconnecting the wires from the grid heater next time it's cold and see if the truck behaves the same way.
You said it flashes the dash lights while driving. Does this only happen when moving slow, or at higher speeds as well? The intermittent nature almost sounds like you only have issues when the grids are powered, which makes me think of a short or poor connection.
Old Jan 25, 2013 | 09:28 AM
Hey thanks aggiejustin I will definitely try that, yeah once again its 68 deg this morning and everything is workin great so maybe it will cool off so I can try that bc I'm tired of searchin
Old Jan 25, 2013 | 04:58 PM
madhat's Avatar
Administrator/Jarhead
Are your batteries the original ones? If so, my money is on a battery going south. Our trucks do funky things when a battery is on the way out.
Old Jan 25, 2013 | 07:01 PM
They very well may be I have had the truck for a year now and they are the ones that were on it when I bought it I have been meaning to swap them for some optimas I was thinking about that the other day if that could be the problem I will Definatley try that and let y'all know thanks for yalls help
Old Jan 26, 2013 | 07:54 PM
Hey guys thanks for all yalls help i picked the truck over for a couple hours last night and found that the light switch was bad i put a new one on just now and everything is working great and i hope it stays that way, but i believe that was the problem this whole time
Old Jan 26, 2013 | 09:38 PM
madhat's Avatar
I hope that is what it is, buddy. Semper!
RD TRCTR
Nov 28, 2007 08:07 AM
nate_o23
Sep 21, 2007 09:59 PM
ontheedge
Feb 2, 2007 08:18 PM
caleb
Aug 26, 2006 09:02 PM
Micaiahfied
Dec 19, 2005 10:25 AM
