04.5 With Edge Juice SMOKE?
My first mods were intake/exhaust/Edge Juice and it would smoke all right but had to be in atleast the high 4's. I then added a Diablo Puck and power wise it helped down low, can't remember about the smoke though. When I added the Quad race, and/or the Diablo Predator, it smoked very nicely
. I hope to be able to send mine in soon for the Hot upgrade
The standard Juice/Attitude on my 04.5 smoked very little and then only on 4/5 or 5/5 if it was lugged. Still not much even then. It is a pretty efficient and safe moderate performance box.
I would agree with omaharam on the hot unlock if you want smoke. I think the you're only looking at 100 hp max on the stock box. With added timing I wouldn't think you'd get much smoke. Watch your temps!
You could short pin c and d on the map sensor, that would make the Attitude think it has full boost, and therefore it would go to full fueling. Do a search for a Smoke Switch
The reason you dont have excessive smoke is because your engine is running efficiently with the edge box. Throw a towel over your airfilter if you want to be a redneck and dump pointless smoke out
Oh for sure...be sure also to do a search and try out Hoss' bedliner tips.
If you want some pointless smoke you could toss a couple quarts of your used engine oil (filtered) into the fuel tank..
