What codes are these?
Old Nov 26, 2007 | 10:31 AM
Bill V's Avatar
07, 6.7, 4x4 auto. I have had the recall and updated flashes (au & av). Now have a CEL with two codes stored. P-0420 and P-0471. Any ideas on what these codes indicate? Have checked "search" without success.
Thanks in advance
Bill V
Old Nov 26, 2007 | 11:00 AM
Bill V's Avatar
Found codes!
Thanks for looking but I found the codes on another site. P-0420 is catalyst efficiency below required level and P-0471 is Exhaust pressure sensor range/perf (whatever that means)
Bill V
Old Nov 26, 2007 | 11:02 AM
John Faughn's Avatar
PO 0420 - 1/1 catalytic converter efficiency
PO 0471 - exhaust pressure sensor range/performance
Possible plugged exhaust .
See what dealer has to say , warranty , then post that .
Old Nov 26, 2007 | 10:52 PM
mega-engr's Avatar
"California Style"
I had that P0420 code on my Camry come up quite often recently. My research shows that either the cat is bad or the O2 sensor(s) are bad. Basically, the cat is between two O2 sensors and the computer measures the difference between the two. The right differential means the cat is working right. Little to no differential means tha cat isn't doing anything. Either the cat or sensors could be bad.
Pretty ironic after getting the O2 module replaced... Let us know what happens please.
Old Nov 29, 2007 | 07:09 PM
Bill V's Avatar
?Codes
Took my truck into the dealer for the P-420 and P-471 codes. Service statement indicated that both #1 and #2 exhaust sensors were replaced, as #1 sensor had a reading of 250 degrees more than #2. I believe that this repair was specifically for the 0471 code and the 0420 was just along for the ride. CEL is out and truck is still running well.
Thanks to all who were interested or responded.
Bill V
Old Jan 24, 2008 | 06:34 PM
billmea's Avatar
where can we get a list of the codes???
Old Jan 25, 2008 | 01:30 PM
fred03Ram's Avatar
2nd that. I have found numerous sites with code listings, but none that list P1142, came off a 08 auto 6speed. I think it is trans related, but my code reader says it is "manufacturer specific" any clues or links out there?
Old Feb 9, 2008 | 11:28 PM
DodgeCowboy's Avatar
DTR's Cow Boss
So whats up with P0420 my dads 07 6.7 just tossed this one at us tonight on the way home from dinner? what will the dealer get to replace next under warranty so far its been a thermostat all the o2 sensors
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
tankeryanker
Apr 30, 2004 01:35 PM
Farmall
Feb 3, 2003 09:07 AM
