Transmission will not shift 5th - 6th
Old May 31, 2017 | 12:25 PM
k9prtnr's Avatar
Last couple of weeks my truck has not been shifting from 5th to 6th gear on start up and about the first 2 miles. Then it shifts and works fine the rest of the time. Took it to the trans shop and they feel its a computer issue. Trans checked fine and no issues on the computer. They recommended a trip to dealer. NOT!!!
I have just in-installed my programmer then re-installed it as of now. This is my first action... posting here is my second action.
Anyone got any ideas????
Thanks for your time.
Old May 31, 2017 | 01:16 PM
johnh's Avatar
sounds like temperature is the factor controlling the shift, if there is a temp sensor in the trans, change it!
The trans temp sensor is probably bad. Its on the same unit as the gov pressure sensor.
Old May 31, 2017 | 08:53 PM
k9prtnr's Avatar
Thanks here comes the point were my lack of knowledge and experience will show.
Can you tell me were that is located? Is it something I can do or a shop has to do it?
Old Jun 1, 2017 | 08:15 AM
johnh's Avatar
i think it's inside the trans, pull the pan and it should be there!
Old Jun 1, 2017 | 10:48 AM
mega-engr's Avatar
"California Style"
Are you in a cold climate? This sounds fairly normal to me and part of the programming. My trans won't shift into the OD until it is warm enough as well...
Buckshotram
Nov 1, 2005 11:28 PM
GCSS
May 12, 2005 10:41 AM
Mark Hodowanec
Oct 27, 2004 10:37 AM
More Power
Jan 25, 2004 06:44 PM
