Tone Ring on the 6.7???
Old Oct 31, 2007 | 08:11 PM
Tiara3100's Avatar
I was wondering if the 6.7 has the same tone ring as my 5.9 in my 04.5??
If so, has anyone tried the tone ring mod to increase MPG??
Old Oct 31, 2007 | 08:14 PM
KMKDiesel's Avatar
Are you meaning silincer ring and if so I have taken them out and they are alot different then the 5.9 There is three dowels that hold it in place not a snap ring. I didnt notice any difference and on the 6.7 it looks like it might be there to help channel the air to the turbo
Old Nov 1, 2007 | 02:19 PM
Tiara3100's Avatar
No, not the silencer ring. The tone ring is on the front of the crank. It is used as a timing indicator for the engines electronics.
Old Nov 1, 2007 | 07:10 PM
KMKDiesel's Avatar
Oh ok now I know what you meant I will look into it and see if there is a diff
Old Nov 1, 2007 | 07:42 PM
MegaRam's Avatar
Tiara,
Would you mind telling us more about it......
Removing it...... might make for better MPG...?
And again it is a timing ring located where...?
Sorry this is new to me....
Old Nov 1, 2007 | 07:46 PM
t-boe's Avatar
The tone ring is located on the crankshaft. It's a crankshaft position sensor that tells the ecm when to fire the injectors at certain points in the rotation of the crank. Kind of like a distributor on a gasser.
Old Nov 1, 2007 | 09:22 PM
Smkndzl's Avatar
the tone ring is now part of the balancer on the 6.7
Old Nov 1, 2007 | 09:25 PM
Tiara3100's Avatar
On my 04.5 I modified the tone ring by elongating the dowel pin hole on the tone ring. This advanced the timing of the fuel injection slightly, giving my truck a little more bottom end grunt and about 1-1.5MPG improvement overall. Also made it sound just a little more "Diesely".
Does the 6.7 have the same set up, and would it work???
Old Nov 2, 2007 | 07:06 AM
MegaRam's Avatar
Thanks....
Old Nov 2, 2007 | 07:10 AM
Tiara3100's Avatar
Baldhog,
Does that mean it can't be removed and modified??
Old Nov 2, 2007 | 07:47 PM
KMKDiesel's Avatar
I looked at it and I think you might be able to take it off and modify it but I dont think it would be worth the time and effort to do it. And like was said above its part of the balancer. So it will be a little tricky.
HaulinBut
May 12, 2006 03:06 PM
Mark Hodowanec
Sep 29, 2005 09:15 PM
BossHogg
Sep 14, 2005 09:48 AM
VORTEC87YJ
Mar 23, 2005 08:59 PM
