tire pressure sensor
Old Sep 22, 2009 | 07:11 PM
kschalk's Avatar
Question tire pressure sensor
i was wondering if any body found a way to trick the tire pressure sensor light i put after market wheels and tires on my truck and they did not put sensor in them now light on all the time
Old Sep 23, 2009 | 06:49 AM
Blake Clark's Avatar
Find a second set of sensors, or use the factory set if you wish to not use those rims/tires, and install them.
Otherwise you can use an instant dash light hiding kit....
Old Sep 23, 2009 | 09:02 AM
txfiremedic's Avatar
As of right now, there is no way that I know of to trick the TPMS. I believe Marco and Bob are working on this as an added option to the Smarty. We'll have to wait and see.
Old Sep 23, 2009 | 09:06 AM
That would be awesome. Even with the system in place its a Pain....
Besides, most of us are SMART enough to check our tires regularly....
Old Sep 23, 2009 | 07:18 PM
gsbrockman's Avatar
Even in wheels that allow an OEM TPMS sensor to fit correctly, often times the aftermarket tire/wheel combo will generally utilize a lower inflation pressure that works properly on the truck and makes a good contact patch, but will be below the threshold values of the OEM tire pressures in regards to light load / max load tables that are already programmed into the TPMS system.
I'm really glad my 2007.5 has no TPMS !
Greg
Old Sep 24, 2009 | 06:25 AM
That what I was getting at Greg. Most of the guys on this forums do check there vehicle regularly, not just tires but all vital systems and components.
I was doing this long before Big Brother said I had too, and then annoyed me to death with a little yellow light about it.
TucsonDiesel
15
Aug 28, 2016 11:37 PM
Redlinear
Feb 14, 2013 01:10 PM
wesboyd585
Dec 9, 2008 05:48 PM
Bobcat698
Mar 25, 2008 09:42 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
