There's No Grease Fitting At Front U-Joint
Old Mar 25, 2008 | 07:08 PM
mr. ed's Avatar
I know this subject has been brought up concerning that hard-to-find grease fitting at the U-joint on the front driveshaft. Some folks on this forum have stated that there IS a fitting which takes a special type of grease gun in order to access it.
Well, I took my truck to a lube center the other day to have the oil changed and asked the people there if they could locate a fitting. Try as they might, they couldn't locate one. They then decided to get on their computer and, using my truck's VIN, brought up a diagram on the screen that showed all the lubrication points on my truck.
Guess what? The diagram showed NO grease fitting at all in the front shaft U-joint! Is their diagram wrong or is there in fact a hard-to-find grease fitting on these trucks? I'm a bit confused here..thanks in advance.
Old Mar 25, 2008 | 07:22 PM
acoustic_axe's Avatar
I have it on mine, it's a concave disc about the size of the eraser on a #2 pencil, silver color in color. Has a small idention in the center for a needle type grease gun tip.
It's a real pain, more grease goes around than in it.
Just went out and looked at my trucks u-joint, it's on the double u-joint at transfer case. There doesn't appear to be one at the front differental.
Go figure.
Old Mar 25, 2008 | 11:55 PM
Jeff K's Avatar
Your front driveshaft will have a grease fitting. See the attached thread for the location of the fitting and the correct tool to use
https://www.dieseltruckresource.com/...d.php?t=181267
twincam2000
Sep 6, 2011 04:14 PM
BKCBUILDER
24
Oct 8, 2007 09:13 PM
Tiara3100
22
Feb 6, 2007 02:33 PM
Tiara3100
Feb 5, 2007 04:14 PM
chuxtruk
Mar 2, 2006 12:17 PM
