Starting issue
Starting issue
Hi all, having a starting issue. Truck is 2007 6.7 auto trans with full deletes using H&S minimax. Have not been having any problems or signs of bad batteries. Always started right up every time until yesterday morning. Turned the key on and waited for wait to start light to go out. Tried to start and got clicking from starter solenoid. Tried couple more times and then got nothing at all. No codes.
Attempted to jump start but again nothing, not even the clicking. Took batteries out and charged over night. Battery tender chargers indicated fully charged by morning so reinstalled and still nothing, not even clicking.
Took the batteries and had them checked. 1 battery was questionable and the other was good. Replaced both batteries with 1060 CA 900 CCA but same results. Do not even get the solenoid clicking. All lights and dash ligts come on when key turned to run. Radio is off but time is displayed, this goes off when turn key to start. Key fobs still lock and unlock doors. Programmer still communicates with ecm and still no codes.
Any suggestions would be very much appreaciated.
Already cleaned all cables at the battery terminals even though no sign of corrosion. Missed cleaning the ground to engine block. Will try that before I replace any other parts. I was thinking I may have messed something up trying to jump start it as I know these trucks are very sensitive to voltage and poor batteries cause all sorts of symptoms. Thanks.
Does the solenoid click? If yes, the contacts may be fouled. If no, the low voltage wire may be a problem, or the coil may have failed. You can check all this stuff with a jumper cable. What about the solenoid terminals and the starter terminal?
No clicks from the solenoid. Cleaned the high voltage cable to starter. Did not remove the low voltage connector. Need to try and push the truck into my garage, much easier to work on and a bit warmer. Thanks for your input. Sounds like I need to concentrate on testing solenoid and it's circuit.
Put 12V directly on the solenoid coil terminal. No action means a new starter. If it does engage, then look at the interlock.
I'll give that a shot this weekend. I did attempt to start in N and then put back in P just in case the gear selector lever wasn't in park all the way. Same results, nothing at all. Trans is auto. Again I very much appreaciate the information and suggestions, hope you have a great day.
fourthandgoal
88
Dec 27, 2011 05:39 AM
abc4yew
Mar 15, 2007 11:55 PM
