Sooting issue
Old Oct 18, 2011 | 02:45 PM
dcwolfe85's Avatar
Sooting issue
Not really an emergency, but i was wondering if there is a way to clean the turbo and exhaust filters myself w/o taking it to the dealership?
Old Oct 19, 2011 | 03:41 PM
Gatorama's Avatar
Welcome to the forum. Fill out your signature so we know what your truck is. Do a search for DPF, EGR, turbo cleaning, etc. This is a very "popular" subject with the 6.7 owners. There is a great article about cleaning the EGR valve on the top of this page. Driving in "tow/haul" and using the exhaust brake helps to keep the soot from building up in the turbo. There are hours of reading material on this subject in this forum. Enjoy.
Old Oct 21, 2011 | 10:21 AM
dcwolfe85's Avatar
Thanks for the reply...got a question though. If i install a dpf delete pipe, do i need to run a programmer to bypass the sensors and/or fault codes?
Old Oct 21, 2011 | 01:03 PM
klx650a2's Avatar
Yes you need a programmer after you do the deletes otherwise the computer will go into fits due to the miss readings from the sensors.
Old Oct 21, 2011 | 02:59 PM
BigIron70's Avatar
Cummins Guru
You can clean turbo if you have special tool and the turbo has a drilled cleaning port. Tool is $300 + special cleaning fluid. If under 100K miles and turbo P2262 code is setting cleaning would be covered under warranty. DPF is only cleaned during a regen cycle, if check engine light is on then regen could be disabled causing DPF to plug up with soot. When that happens engine power will be derated and see dealer will appear in the overhead display.
Old Oct 22, 2011 | 02:48 PM
dcwolfe85's Avatar
Ok thanks for the info, ive already took it to the dealer and everythings back to normal...guess it wud b easier to just let the warranty do its job and let them clean it for me when its needed
dan123dbl
Feb 13, 2015 05:47 PM
jayjma20
13
Jan 20, 2012 10:11 PM
DDysput
May 5, 2004 07:44 AM
DieselDaze
Oct 30, 2002 12:07 AM
