shake
Old Aug 10, 2009 | 09:23 AM
cowboy1814's Avatar
shake
Im having a issue with the front end of my truck . If i hit a large enought bump on the road , the truck will shake like like the front tires are comming off,seems to do it with or without a trailer. I took it for the front end recall dealership said everthing was fine. If anybody can help id appreciate it.
Old Aug 10, 2009 | 12:51 PM
Jim W's Avatar
When you go across railroad tracks will the front end shimmy also? Are you running stock size tires?
When I use to run Jeeps this was a common problem with the front steering stabilizer. The stabilizer will fail over time depending on how big of a tire and how many road bumps you hit. The steering stabilizer is a maintenance item. You will need to be replace the steering stabilizer after some road miles are placed on your truck. This can be replaced by a Mopar or aftermarket item. I would look into an aftermarket if you are using non stock size tires.
Sometimes you will need to run two stabilizers, this will depend on tire size and suspension.
Old Aug 10, 2009 | 04:04 PM
patdaly's Avatar
Do a search on "Death Wobble"
Old Aug 10, 2009 | 06:34 PM
mega-engr's Avatar
"California Style"
That's what it sounded like to me as well; death wobble. Fill out your signature and truck info.
Satman30
May 28, 2008 01:48 PM
ric o'shea
Mar 24, 2007 10:50 PM
Nuttymopar
Dec 18, 2003 07:01 AM
BigBlue
Sep 9, 2003 03:05 PM
antknee
Jul 3, 2003 01:06 PM
