Rear main seal
Old Oct 4, 2008 | 06:45 PM
chrisfer's Avatar
Rear main seal
I am changing my clutch and I noticed that the rear crankshaft seal has a tiny amount of oil on it. It is clearly used diesel oil. I already installed the clutch, but didn't put the transmission back on yet, but now I am slightly concerned about this. The truck is an 07 with only 20k miles. If this is a sign of it going bad, I can change it easier now than later. I don't want to be without my truck waiting for the part, but its worth not having to take it apart again. Or maybe, since its under warranty for a while, I should just leave it alone and take it to Dodge if it goes. I hate having other people work on my truck though.
Any ideas?
Old Oct 4, 2008 | 09:40 PM
Cummins610's Avatar
I can't help you but I think this is urgent enought so you should repost this in the "HELP" section at the top of the fourm.
Old Oct 4, 2008 | 09:47 PM
mitternocht's Avatar
You know I saw the same thing when I did my clutch. I went ahead and put a new seal in while I was at it. However I don’t think that the seal you see when you have the flywheel off is really the only oil seal. I think it might be more of a dust seal.
I might be wrong; hopefully someone else will chime in. I hadn’t even thought about it until I saw your post.
I think I got the seal at my local Autozone. Either way I think you’ll be ok. If seals don’t let a little bit of oil through for lubrication they’ll dry and burn up.
Here is the PN from AutoZone, NAPA and what not might have it too. The one I got had the seal and a gasket for the engine to trans adapter plate.
About this product:
Part Number: BS40692
Weight: 0.43 lbs.
Note: PTFE rubber 1 piece
Pricing: $22.99
ted_pulliam
Aug 4, 2010 11:33 AM
bnold
Jul 7, 2007 06:18 PM
chaikwa
Mar 24, 2004 09:23 PM
okcummins
Dec 21, 2003 07:45 PM
Mostwanted
Sep 17, 2003 06:55 AM
