Rear brakes???
Old Dec 21, 2008 | 10:56 PM
jsledder's Avatar
Rear brakes???
I pull the truck in the garage tonight, shut the door and go to back up a little bit and notice that the rear tires are spinning while I have the truck in reverse at idle. So I pull it back outside and try it in forward and it does the same thing, snow outside but the garage was dry. I have noticed that this thing locks up the front wheels real easy when coming to a stop and it doesn't feel like there is any brake in the back, and when hooked to a trailer it's even worse.
Old Dec 22, 2008 | 08:22 PM
mitternocht's Avatar
That doesn’t sound right, maybe the proportioning is off? Do you have a good dealer you can take it to in your area? I’d think you’d still be under warranty.
Old Dec 23, 2008 | 08:29 AM
jsledder's Avatar
Evidentally not, called every one within 100 miles and they all said they are busy and that I should take it back to where I bought it so they can look at it, even after I told them that the place I bought it wasn't a Dodge dealer. I also asked them what they thought of my crappy mileage and if there might be a new flash available? "8-9 is about all your going to get with that in the winter".
Anyone know a "good" dealer in the upper midwest????? The place I bought it can do warranty work on everything but the computer, they are a chrysler dealer but don't have the programming for the Dodge products????
Old Dec 23, 2008 | 10:07 AM
Scotty's Avatar
Top's Younger Twin
Probably too far for you but I needed some work on my 04 awhile back and was passing through Fargo...wheeled into Corwin expecting to be told they are busy too. The service mgr saw that I was from out of town and needed some work. I waited for 2 hrs and then they had it in, fixed and on the road in less then an hour. It was a fix that was not done correctly by a dealer in Canada. No charge either. I went up to the front and found Drew Corwin...the son and let him know how I was looked after and ended up buying my Mega Cab from them about a year later.
Scotty
Old Dec 23, 2008 | 02:17 PM
jsledder's Avatar
I'll be going through Fargo friday, I'll give them a call and see if by chance any mechanics are going to be around and would have time to look at it.
Thanks
1992 Renegade
Oct 11, 2014 03:29 PM
2500CTD
Oct 19, 2010 07:10 PM
wildcargo
Nov 29, 2005 04:20 AM
JImbo1
13
Apr 18, 2003 06:44 AM
