Read and Clear Codes
Old Jun 4, 2007 | 09:14 AM
Rrloren's Avatar
Will the Actron CP9135 or CP 9125 work on a new '07 with the 6.7 engine? Will it clear a check engine light?
Old Jun 4, 2007 | 10:19 AM
rcotton's Avatar
Here is some of the technical bulletin numbers for 2007
2007 DODGE RAM2500 MEGACAB 4X4
Bulletin Number: 0200107
WHEN BRAKING THE VEHICLE MAY DRIFT TO ONE SIDE OR EXHIBIT A BODY SHUDDER. *KB
Bulletin Number: 0300306
AXLE FLUID LEVEL. *KB
Bulletin Number: 06053
DIAGNOSTIC TROUBLE CODE (DTC) P0191, FUEL PRESSURE SENSOR RATIONALITY. *KB
Bulletin Number: 0803006
POWERTRAIN CONTROL MODULE INITIALIZATION. *KB
Bulletin Number: 0804406
DIAGNOSTIC TROUBLE CODE (DTC) C1240, STEERING ANGLE SENSOR OVER TRAVEL PERFORMANCE. *KB
Bulletin Number: 0900107
INTAKE - TO - THROTTLE BODY JOINT MAY CAUSE A WHISTLE - LIKE SOUND ON 3.7L ENGINES. *KB
Bulletin Number: 1400306
CUMMINS DIESEL DIAGNOSTICS. APPLIES TO VEHICLES EQUIPPED WITH A 5.9L CUMMINS 24-VALVE DIESEL ENGINE. *KB
Bulletin Number: 1400506
5.9L AND 6.7L CUMMINS DIESEL ENGINES - CORRECT LOW AND ULTRA-LOW SULFUR HIGHWAY DIESEL FUEL USE. *TT
Bulletin Number: 1800106
STARSCAN@/STARMOBILE ABORT RECOVERY PROCEDURES. *TT
Bulletin Number: 2100207
TORQUE CONVERTER SHUDDER / SHIFT QUALITY IMPROVEMENTS / DTC P0732. *KB
Bulletin Number: 2304706
CRACKED WINDSHIELD DUE TO BEING HIT BY A FOREIGN OBJECT LIKE A STONE. *KB
2007 DODGE RAM 2500
Bulletin Number: 0600107
CLUTCH SYSTEM MAY OVER-ADJUST CAUSING DIFFICULTY ENGAGING TRANSMISSION GEAR. *KB
Bulletin Number: 1800107
CHECK GAUGES LAMP ILLUMINATES FOR ALTERNATOR CHARGING WITH DTC P2502, P2503, OR P2509. *KB
2007 DODGE RAM 3500
Bulletin Number: 1400706
FUEL AND FUEL FILTERING REQUIREMENTS FOR CUMMINS 5.9L AND 6.7L ENGINES. *KB
Bulletin Number: 1803206
5.9L DTC P0191 - FUEL PRESSURE SENSOR RATIONALITY. ERASE AND REPROGRAM THE POWERTRAIN CONTROL MODULE (PCM) WITH NEW SOFTWARE. *KB
Bulletin Number: 2200506
FRONT END SHIMMY ON 4X4 VEHICLES WHEN TRAVELING OVER ROUGH SURFACES IN THE ROAD. *KB
Old Jun 4, 2007 | 02:05 PM
Ga_Mike's Avatar
2007 DODGE RAM 2500
2007 DODGE RAM 3500
Thanks for the info....Would be nice if stuff like this could be stickied in the top thread...
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
Deezuhl77
Apr 17, 2007 01:11 PM
hellotbone
Apr 1, 2003 03:11 PM
