pyro
Old May 7, 2008 | 08:50 PM
Teamropinram85's Avatar
pyro
I was wondering which gage setup is out that will allow me to read egt with out drilling and tapping in my manifold . I would like to just plug a plug instead of drilling a whole ?
Old May 8, 2008 | 12:17 PM
DBLR's Avatar
IMHO If you want accurate Pyro readings then you will need to drill and tap your manifold unless you want to put it after the Turbo.
Old May 9, 2008 | 04:01 AM
Swayse's Avatar
I have a Dashhawk in my Jeep CRD, it reads the cat temp.
Old May 9, 2008 | 09:19 AM
mj007's Avatar
You can just drill it after the turbo and mentally add 3 hundred to your readings.
Old May 9, 2008 | 04:26 PM
mikmaze's Avatar
the probe has to be in the air stream of the exhaust to get n accurate reading, afraid of drilling, you could always buy an aftermarket manifold that is pre drilled and then be one up n flow over stock to boot.
Old May 11, 2008 | 11:18 AM
judge88's Avatar
the 6.7 already has a probe in the manifold from the factory. not sure what its purpose is but i know the bullydog pmt uses it for there egt reading via usb port.
Old May 11, 2008 | 07:58 PM
coolbreeze's Avatar
Cummins doesn't seem to put much store in exhaust temp until V12 or V16 size. Check with them.
Clay
Mar 21, 2003 10:53 PM
RAMTECH
Mar 9, 2003 12:49 PM
FiverBob
24
Nov 27, 2002 03:32 PM
bdog
Nov 5, 2002 02:09 AM
bkay
Oct 15, 2002 06:32 PM
