P061C ETC Level 2 Rpm Performance
Old Feb 23, 2010 | 05:52 PM
apocalypse1812's Avatar
Got this code today, the Red lightning bolt came on, I dont know what it means, it runs and drives fine. I have an airraid intake, EGR?Cooler Delete, DPF Delete, and an Edge Juice/Attitude. I clear all codes, start it up, and about 30 seconds later, red lightning bolt comes on, and throws the code again. Any Ideas?
Old Feb 23, 2010 | 08:04 PM
Blake Clark's Avatar
Not sure why that would come up, never had it show on mine with the Edge. Do you have the throttle valve delete? Maybe check the plug at the throttle valve make sure its in good or no wires pulled out.
Im pretty sure that the Edge alone will not allow for throttle valve deletes.
Old Feb 24, 2010 | 06:35 AM
I just have the butterfly valve in the intake taken out.
Old Feb 24, 2010 | 11:26 AM
Im not sure now, maybe someone else will chime in and help you out.
Old Feb 24, 2010 | 12:56 PM
Chubby's Avatar
Take the map ( boost pressure) sensor out of the loop . Just plug the stock harness into it. I have returned my edge 2 times for this problem. Now I just use it for a egt gauge , smarty installed.
Old Feb 24, 2010 | 06:11 PM
Lil Dog's Avatar
I think the Butterfly actuator might have something to do with the lightning bolt. Not sure.
RiddlerLS1
Jan 11, 2008 11:48 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
fishin fever
Feb 22, 2004 08:32 PM
