Noise under drivers side dash
From: This Nazi state of California 2nd home Gilbert AZ under God
Anyone have a clicking noise under or in the dash on a 08? I started out at 4:00 this morning and have this new irritating noise I thought maybe it was a cable harness or something loose but can not find it. Even opened the hood and everything is tight.
had a funny noise on my 09 sounded in the dash pass side it end up being the to ac lines weree rubbin under the hood right behind the air box toward the firewall just pulled them apart went away
I had a similar noise on my '08 that sounded like it was under the dash, but it ended up being the outside mirrors when set in the towing position. They would creak a bit in strong winds but it sure made it sound like it was coming from down low. Also, check the area where the dash meets the plastic cover for the A-pillar. Mine was a touch off when I got the truck. Pushed it in and noise stopped.
Cummins Guru
Unusual noise heard in passenger cabin while driving. Noise may occur in specefic gears only. Noise may change or cease if the automatic transmission is downshifted manually.
System or Component Noise;Customer Concern (No DTCs);Automatic Transmission / Transaxle;Yes - Intermittent,Yes - Continuously
Recommendation The noise source may be the auto trans cooler tubing and the noise may be transmitting into the passenger cabin via the auto trans shifter cable. Check for proper routing of the trans shift cable away from the trans cooler tubing. Install shift cable retaining clips or zip ties as required to prevent shift cable contact with trans cooler tubing.
I have a noise from my passenger side dash. Its a vibrating/rattling sound. Its not under the hood. You can only hear it in the cab. Doesn't do it all the time. Most prominent between 1500-2000 rpm sometimes if im parked on a hill or something it will do it at an idle. Any ideas?
Sent from my DROID2 GLOBAL using Tapatalk
joem
Apr 10, 2012 12:14 AM
koondawg
Aug 19, 2006 05:08 PM
heavyg
Jun 24, 2003 07:43 AM
