Need help with upgrades
Old Mar 14, 2010 | 07:55 PM
tedsawicki's Avatar
I have a 2008 3500 with a standard transmission. I changed the wheels and tires to 35 1250 20. I went to the dealer to have the computer adjusted for tire size and to have the fast idle enabled and the said that they can not find any PTO setting or fast idle, they also said that they can not adjust the program to allow for a tire that big. Anybody know what i should tell them to look for.
Old Mar 14, 2010 | 08:50 PM
Blake Clark's Avatar
Take a look at this thread
https://www.dieseltruckresource.com/...nual+high+idle
I dont think you can adjust to that large of tires with the starscan. You may have to find some other means of doing it.
Old Mar 14, 2010 | 10:16 PM
tedsawicki's Avatar
Thanks Blake I did ground the little green wire but it still does not work do you think now that i have it grounded that the dealer will see this on there programer
Old Mar 14, 2010 | 10:28 PM
Once that wire is grounded they should be able to activte it. It's just a simple walk around of the clutch bypass switch.
Apocalypse
14
Mar 4, 2009 08:34 AM
jmccart
Jun 7, 2007 01:00 PM
jeepfun
Jan 14, 2005 03:49 PM
y-knot
Aug 20, 2003 08:16 PM
