More questions
Old Mar 3, 2010 | 03:15 PM
Navy7797's Avatar
More questions
What is the small flexable pipe coming the bottom of the tubro to the block near the oil pan ?
If I loosen the clamps on the tubro and Cat pipe, can I remove the elbow between the two, to drill and tap for a probe ? Or is i next to impossable to get out ?
thanks for the input
Old Mar 3, 2010 | 11:16 PM
nwflyoda's Avatar
i believe that is the oil return line dumping the oil back into the pan after it goes through the turbo. i don't think its any different than on my motor but i could be wrong.
the best place for the probe is the manifold. you will get a more acurate reading for the egts. if you drill it there, you will need to keep in mind to add another 400 degrees to what your gauges says for an idea of the real exhaust temp.
Old Mar 4, 2010 | 02:14 PM
Blake Clark's Avatar
Yup,
Flyoda is right, best place for it is in the collector of the manifold. If you want I can get you a pic of where mine is.
Old Mar 4, 2010 | 02:28 PM
Navy7797's Avatar
pic
Yup,
Blake: Thanks but thats not necessary I saw a good pic on one of these web sites. I'm just worried about getting metal in the turbo.
thanks
gordon
Old Mar 4, 2010 | 02:34 PM
No worries. Itll just blow through. Did mine just as Edge recommended and had no adverse effects.
Old Mar 4, 2010 | 05:36 PM
mega-engr's Avatar
"California Style"
Mine worked fine too. drilled in increment to have small chips and used grease on the drill and tap. I drill mine while ideling the motor to make sure anything blew back out. Just used the grease for the tap. I stuck a vacuum in the area before firing it back up too.
92smokin blacky
Mar 19, 2010 11:39 AM
JyRO
Jan 20, 2006 09:28 AM
j
Dec 21, 2003 10:26 AM
Commatoze
Nov 20, 2003 06:06 PM
