Maintenance Required Light
Service Required Light
I have the "service required..take to dealer" light on displayed on the overhead console. I have 76,300 miles on it and it just came up. What is the light for and more importantly how do I reset it.
I had the "perform service" light on before and i changed the CCV filter. resetting that light was easy. I searched on here and it was said to.
1. turn ignition on
2. press brake pedal twice
3.press accerlerator twice slowly within 10 seconds
4.turn ignition off
I tried doing that to reset the service required light with no luck.
Thanks!
1. turn ignition on
4.turn ignition off
Thanks!
the maintenance required light will never set a code because its not a malfunction. its a reminder to change CCV filter and do EGR clean (on non deleted trucks of course) but the light still has to be reset.
my 08 came up with this problem a bit after got my smarty s67 all i had to do is load stock prog. back in truck then load the smarty back up and was back on the road in 10 min had to do this bout every 10000 km or so
