light and three codes
Old Dec 21, 2016 | 07:57 AM
tn terry t's Avatar
hello I have a 2008 dodge 3500 with the cummins engine and automatic transmission bone stock nuthin done to it. my son drove it to work Monday morning , about 35 miles. as he pulled in the parking lot the check engine light came on. he drove it home that evening we pulled the codes
with a obd reader we got P042E P242F and po420 then we noticed the dpf 80 % full on idle then it would flash regeration in progress back to 80 %full I drove it down the road it goes to 100 % back to 80 % when stopped a few minutes later it went dpf full see dealer then reduced power if I delete all this crap do I still have to take it to a dealer to get it out of this reduced power mode? any and all help is very welcome and very needed
Old Dec 21, 2016 | 08:58 AM
johnh's Avatar
when you install a programmer and do the deletes,clear the codes,you should be ok. but that's just my opinion
Old Dec 21, 2016 | 05:41 PM
tn terry t's Avatar
thank you . hey I know nothing about this after market stuff . we have a 2001 and this 2008 never done anything to then cept drive them. any other thoughts on what would work good for me on this stock truck
Old Dec 21, 2016 | 10:49 PM
BigIron70's Avatar
Cummins Guru
EGR valve is stuck open. You can try cleaning it but if code returns you will need to replace the valve $800. You will need to have a stationery regen performed if at 100% and derate in power.
File Type: pdf
sallyman1
Aug 26, 2008 06:20 PM
$oC@l CTD
Jul 18, 2007 11:41 PM
robox
Apr 15, 2007 08:01 PM
Puke
Dec 11, 2005 10:52 PM
