lifting question
Old Feb 11, 2007 | 01:23 PM
Rogers954's Avatar
lifting question
Im new to the lifting thing and was wondering if I put on a 3inch body lift shocks and a leveling kit (on a 05 2500) will will I be able to use it still if I decide to put on a 6inch suspension later or will I have to take it all off. And do you need to level it if you put on a body lift or will the body lift make it sit level??? any help much appreciated
Old Feb 11, 2007 | 01:33 PM
'strokeThis_'07's Avatar
You can add a 6" suspension later and still keep your 3" body. The body lift won't level it out. The leveling kit actuall raises the suspension about 2" with either a coil spacer or a longer coil. Some don't like using a body lift, as I think it puts more stress on the body mounts on the cab. I don't have any actual experience with either but have read alot on this and other forums, and if I'm wrong somebody will correct me.
Old Feb 11, 2007 | 02:25 PM
Rogers954's Avatar
Which leveling kit do you guys think is the best
Old Feb 11, 2007 | 10:07 PM
walnutfarmer's Avatar
A friend of mine has an 05 with a 3inch body, 6inch lift, and the 2 inch spacer. works and looks great. And I would go with a Daystar Spacer.
drewsta
Jul 24, 2011 04:01 PM
jet
Jun 25, 2004 12:09 PM
cfm3110
Nov 12, 2003 05:14 PM
MARKY MARK
Sep 20, 2003 02:17 PM
Superduty12v
21
Sep 19, 2003 08:00 PM
