how many qts. of trans fluid?
Old Mar 3, 2011 | 03:28 PM
thaimonkee's Avatar
My transmission pan was starting to seap some fluid so i decided to drop the pan to reseal it. While im down there im goig to change both filters. Does anyone know how many quarts of ATF i wll need to top it back off. Looks like I drained around 10 qts. And do you add the trans fluid trough the dipstick like most traditional cars?
Also why did Dodge make a drain plug on the transmission pan? I made ahue mess draining the fluid out of the pan.
Old Mar 3, 2011 | 04:00 PM
mega-engr's Avatar
"California Style"
When I did mine, it was about 6 or 7 quarts for just the draining... I guess Dodge doesn't see the value for implementing and adding in cost for drain plugs because it is not done as often as an oil change...
skindaddy
Feb 1, 2010 01:00 PM
smokinram99
Jan 6, 2009 09:00 AM
Cummins4Life
Aug 14, 2006 12:05 PM
jeepsuck
Dec 26, 2005 02:17 AM
97catintenn
Feb 11, 2005 01:47 PM
