draining more qts of trans fluid
Old Feb 1, 2010 | 07:04 AM
skindaddy's Avatar
DRAINING more qts of trans fluid?? HOW
what ways are there two drain more than 7 qts of trans fluid out , before or after pulling pan , i would like to get most out if i can.
would some come out if i drained pan (i have b&m plug installed) put truck in neutral and cranked truck over without truck starting, would that circulate more to the pan.
thanks for the ideas
Old Feb 1, 2010 | 07:54 AM
05HDRAM's Avatar
Do a search, there are a couple posts on this topic. When I changed my fluid, I dropped the pan and changed the filter. Added 6 qts and pulled the return line at the tranny. Ran a hose into a 5 gal bucket, started it up and put it in nuetral. Pumped about 5 qts (watched for it to start slowing down), shut it down and added the same amount I pumped out. Ended up changing about 14 qts when the fluid pumping out started looking nice and clean.
Most say just drop the pan, but I can tell you my tranny is shifting smoother and not getting as hot by changing more than 6 or 7 qts. It was super easy and did not add more than 10 minutes time vs just dropping the pan.
Old Feb 1, 2010 | 08:14 AM
mini14's Avatar
^^^^^agreed...........pulling the line takes 2mins. connect a 5/8 clear hose to the end and your gtg.
Old Feb 1, 2010 | 08:29 AM
FLYH2O's Avatar
What hose is the return line?
Old Feb 1, 2010 | 10:26 AM
05HDRAM's Avatar
Back of the tranny on the drivers side.
FYI, I pumped out about 4 qts before dropping the pan. It made it much easier to keep from getting fluid everywhere.
Old Feb 1, 2010 | 01:00 PM
FLYH2O's Avatar
Thanks
thaimonkee
Mar 3, 2011 04:00 PM
smokinram99
Jan 6, 2009 09:00 AM
KRB
Jun 20, 2007 03:10 PM
03CTDCO
Feb 22, 2005 11:46 AM
