How long before MDS in the Cummins?
Old Feb 22, 2007 | 07:02 PM
BLACKBIRD8200's Avatar
Originally Posted by magram
The system was designed around what is called a "lost motion device." DaimlerChrysler engineers designed the Hemi with a separate oil circuit controlled by four solenoids that apply oil pressure to eight specially configured hydraulic roller lifters. When the computer decides to deactivate the cylinders, the solenoids are electronically engaged and oil pressure is sent to the lifters via a separate oil passage in the block that pushes on a small pin that allows the internal piston in the hydraulic lifter to disengage from the lifter. The lifter body still rises and falls with the cam lobe, but the piston that is linked to the pushrod remains stationary. DaimlerChrysler engineers state that the system can deactivate four cylinders within 40 milliseconds (0.040 second). Both the intake and exhaust lifters for each cylinder are deactivated. Every other cylinder is deactivated so the transition from eight to four and four to eight cylinders is seamless. We've driven both the new Dodge Magnum and the Chrysler 300-C, and it is impossible to tell when the engine is running on four cylinders and when it doubles back to eight
Thanks I always like to learn new stuff.
Old Mar 2, 2007 | 10:25 AM
Road Traveler's Avatar
Originally Posted by own1bigtruck
and think of how much brake power you would gain, not to mention how cool it would sound through str8 pipes! Im all for a real jake brake!!
Well at the SEMA show this year I was talking to a guy about that. He seems to think it isnt that far off to see a real Jake in smaller trucks!! Oh the fun that will be!!!
Old Mar 2, 2007 | 07:33 PM
12PACK's Avatar
In January a friend of mine bought a 1500 Hemi and also said the switch from 8 to 4 is seemless. He's yet to notice a delay in getting power when he needed it on the highway. This is one of the reasons he's stayed with Dodge. This 07 replaced his 00 which replaced his 96, all gassers. He was going to go back to Toyota but figured he'd get more truck for the $$ and the mileage would be about the same.
SUPRDUD
Jan 18, 2013 10:33 PM
desertchecker
14
Feb 18, 2008 09:32 AM
wreedCTD
Mar 29, 2007 06:19 AM
CNesloney422
Oct 30, 2006 04:53 AM
Tfeore
Sep 16, 2005 12:21 PM
