Help in Houston area
Old Mar 14, 2008 | 09:46 PM
Teamropinram85's Avatar
Smile Help in Houston area
can someone in the Houston area help me ground my 22 pin to enable my high idle the dealer already enabled it I need to get grounding cause the dealer want have anything to do with it if anyone can help pm , reply or call me 832-771-2081
Old Mar 15, 2008 | 07:30 PM
ok well does anyone have any picture direction on grounding the #22 pin cuz I'm clueless on the ECM
Old Mar 15, 2008 | 08:13 PM
mastercaster's Avatar
ground the wire down on the firewall. i did it and have written about it on here. works like a charm. here are my instructions from a previous post....
you don't need any extra parts to enable the high idle on a manual trans!! i did mine and have posted how to do it before (on other forums). you need to have the dealer enable it, just like on the auto trans. the only other step is to ground the one wire. the wire is located on the firewall. driver side, far left bottom firewall. basically if you go staight back from the emergency brake handle to the firewall, you'll see a large wire harness, white in color. you can unhook that harness, and behind it there is a very short (4 inches maybe) dark green wire coming through the firewall. the wire has a heatshrink cap on the end. strip the end of the wire and ground it to one of the two bolts next to the harness. that's it! let me know if you need more info. you'll need your flashlight to see that little wire back there. that's it folks no money on any parts. that wire is for the optional clutch safety switch. it is really not needed, as the transmission has to be in neutral and the emergency brake set, in order for the high idle to activate. if you touch the brake pedal, release the emergency brake or put it in gear, the high idle will disengage."
Old Mar 16, 2008 | 01:16 PM
got it grounded works too thanks
Old Mar 16, 2008 | 07:25 PM
cool. glad to hear it.
03CTDCO
May 26, 2009 12:31 PM
farmerlee
TXDTR #42
Apr 3, 2008 08:01 PM
pwrtripls1
Jan 18, 2008 10:36 AM
lunchbox
Nov 9, 2002 08:28 PM
