Help
There's a fuse in the PDC under the hood that controls the security system, door locks, and power windows; That'd be my first check.
When you talk about the key, do you mean you get no gauge movement or warning lights when the key is in the "run" position?
Just an update to let you'all know,I did some searching on the web, here and elsewhere, and came up with "wireless control module". Apparently when its cold, sometimes inserting the key can cause an electrostatic charge and lock up the security system or the WCM. I unhooked both batteries for about three minutes and BINGO truck starts. There is a service bulletin out on this for 07 trucks. The odd thing to me when this was happening was neither key fob worked the door locks and I could not turn the key to the on position before turning it to the point where the gauges lit up????? Also I saw where you could remove fuse #11 and achieve the same thing as removing the battery cables. After getting it going I checked for codes and got nothing. Thanks everyone for your help, Sam
2500TurboDodge
Jul 31, 2006 04:21 PM
