Easy/best method to change oil filter on 6.7?
Old Apr 30, 2008 | 02:46 PM
Oilguy's Avatar
Originally Posted by alMout
Not sure if the 6.7 is the same as the 5.9, but you can take the filter off with no spill. Open the oil drain on the pan then go do something else for 30 minutes. During this time, the oil will drain out of the filter mount and when you remove the filter, you will get no spillage, provided you don't tip the filter.
Works great unless you have a beer or two and forget where you left off... My rule is never leave a job until you are finished.
Your right though >> I have found that if you loosen the filter and let is "breathe" just a bit and then pull the plug it will siphon off the top of the filter... I do this all the time of heavy equipment because they take longer to drain through and tube... But those are much easier to get to than these trucks.
Oilguy
the.hogman
Mar 23, 2011 04:50 PM
zack birge
Oct 29, 2008 07:36 AM
erics76
Feb 27, 2008 11:53 AM
4wlow
32
Sep 11, 2006 01:49 PM
RamWheelsBy4
Mar 18, 2005 12:31 PM
