Drove a 08 6.7 and 08 GMC Dmax today
Old Oct 16, 2007 | 11:56 AM
2003Ram's Avatar
Originally Posted by $oC@l CTD
I can save you some time if you would like. I already test drove the loaded models of all three myself to put together a comparo. The Dodge was my all around favorite truck. Like you said, the new 6-speed feels great...i like it MUCH better than my 48RE...it was the most plain inside, which is fine with me...I mean, it's a truck. I also like yourself was in love with the stock exhaust brake...works pretty darn good. The Duramax had the quickest acceleration, but if the Dodge was 1000lbs lighter like the DMAX, I think that they would be VERY close in that department. Allison is also a good tranny. The Chevy had slightly better interior features than the Dodge and rode a little better. The Ford now...Geez oh MAN, how I love that King Ranch interior and features! By FAR the best of the three as far as body, suspension, frame and interior engineering goes...but boy it was a DOG off the line. By FAR the weakest of the three and most inferior tranny of the three to boot...if that sucker had a Cummins and a 68RFE in it, I would LOVE to get my hands on one!
That 1000 lbs has to go somewhere. Lighter engine? Lighter frame? Weaker sheet metal? Check this link where someone loaded a RZR utility vehicle in a Chevy and dented both wheel wells.
Old Oct 16, 2007 | 02:38 PM
Lil Dog's Avatar
Originally Posted by KMKDiesel
One thing to remember is that ford and dodge made a totally new new engine. The duramax is the same engine with the emmissions equipment added on that will be changing buy 2010 because they are not 2010 emmission compliant. But I would still take my dodge any day over the others, but it would be nice to say I have twins.
Not true. The Dmax is on version 5 I believe.. They have monkied with injection, pistons and rod designs as well as block improvements since the release of the LB7. They have ALL stretched to make emissions, Cummins is the only one that is 2010 compliant NOW... FWIW.
Old Oct 16, 2007 | 04:48 PM
D384D's Avatar
Not to mention the 6.7 shares 30-40% of the 5.9s parts.
Old Oct 16, 2007 | 07:13 PM
Dodge man's Avatar
What's not true? What KMKDiesel said is correct.
Old Oct 16, 2007 | 07:15 PM
Dodge man's Avatar
So it shares some parts, Cummins even calls it a new engine.
Old Oct 16, 2007 | 09:53 PM
Bigiron's Avatar
My brother in law has a 2005 D-Max 3500 DRW 5 spd Allison with all the bells & whistles. It is a nice truck inside and out. Rides nice and performs pretty well, but after driving it I think my truck is considerably faster and I know I get better mileage. Of course his is a 1 ton dully so it weighs at least as much as my 2500. Another thing is that he has overheating problems if he pushes it at all when towing his trailer, which is common from what I hear for the 2005 LBZ engine. I thing that the new LBL engine fixed the overheat problems that they had with the LBZ, but it seems like they have to come out with a new engine about every year, and that can't make it easy for servicing. They will need another new engine by 2010. I will stick to Dodge.
Old Oct 17, 2007 | 07:58 AM
RiddlerLS1's Avatar
i believe 2005's were LB7's (not sure) . only the 2006.5's-2007's were the LBZ's i do know that much.
Old Oct 17, 2007 | 08:41 AM
one4speed's Avatar
'01-'04=LB7
'04.5-'06=LLY
06.5-07.5=LBZ
07.5-NOW=LMM
This is out of my failing memory but its close. There is a half year difference in the somewhere but, I don't recall off the top of my head.
one4
P.S. I drove all three (ford, GMC, dodge) the other day. I will post my comments sometime. All three are fairly impressive if you don't think about the emission issues.
Old Oct 17, 2007 | 10:31 AM
Bigiron's Avatar
Originally Posted by one4speed
'01-'04=LB7
'04.5-'06=LLY
06.5-07.5=LBZ
07.5-NOW=LMM
one4
Oops, I think you're right. My brother in law's truck is a LLY. They have so many different engines it gets hard to keep them all straight, which was one of my points.
Old Oct 17, 2007 | 11:42 AM
duratothemax's Avatar
I wouldnt really call them "different". Most parts are interchangeable between the 4. Basically akin to the differences made to the 5.9 over the years. (YES I know the 5.9 stayed in a certain 'generation' for longer periods of time, but remember the 5.9 also existed in a time when (for the most part) emmissions regulations did not exist...so no changes were really necessary.
Its too bad that the 7.3 did not meet the up coming emmissions regulations. Several main things about it...2 valves per cylinder, etc was not going to cut it as far as the EPA was concerned
LB7 --> LLY changes: Different heads, injectors, variable vane turbo, EGR added
LLY --> LBZ changes: different injectors, new ECM, revised turbo and EGR, intake grid heater added, SLIGHTLY bigger rods and revised pistons (ALL short block parts interchange with all other dmax's)
LBZ --> LMM changes: revised EGR, DPF added, intake air throttle body added
you can pretty much build up a custom duramax grabbing parts from every generation. A lot of guys start with LB7 block's, use LLY heads, use LBZ pistons, etc...
Old Oct 17, 2007 | 04:57 PM
D384D's Avatar
Right, but it seemed like the perfect opportunity to state the obvious
Old Oct 20, 2007 | 01:57 PM
Wobblin-Goblin's Avatar
I tested an '08 F-450 Lariat pickup a few weeks ago. Aside from the engine, that truck is a wonderful engineering specimen. The transmission, suspension, interior, brakes, etc are all better than anything you can find on Dodge or GM.
Not very high on the 6.4L, though, and I simply could never buy a GM pickup even though the D-max is a pretty darn good engine.
I wish Ford could offer the Cummins in its pickups.
Old Oct 21, 2007 | 11:31 AM
beretzs's Avatar
I would think that the Ford would have came up with a tranny similar to the 6 speed Allison or the 68RFE which both have double OD. My old man has an 08 F350 and is somewhat impressed with the truck, but the mileage is not very good. I know it should improve some with more miles, but he is getting less than 14 with it. IT would take a lot of breaking in to get it even close to 20 or even 18. I like Fords, and drove them exclusively before my Dodge, but I can honestly say my Dodge is just as tight and drives very well. Guys are crazy when they tout "how much better a Ford body is". It is crazy. They are all good, it all comes down to what the owner wants to see when he gets into his truck every morning. Scotty
Old Oct 21, 2007 | 01:12 PM
DiEseLjunKy's Avatar
Not really. Who is going to pay $100,000. for there truck?
BTW, I am very happy with the Dodge body, Cummins engine and Dodge's new 6 speed auto, thank you.
You never know. Like every once in a while some of those 1st or 2nd gen guys will come in here lamenting the fact that 3rd gens are now $40K and $50K+ trucks that no-one one can afford anymore. Like ten years from now when they cost $100,000 we'll be like a bunch of old farts talking about the good old days when they were 40 or 50K
Old Oct 21, 2007 | 10:14 PM
StrokeThisCTD's Avatar
to be honest, i was waiting for a reply from the bank on financing for my 08 ford that i already signed papers on , and i took it for a test drive.i was NOT impressed at all. I now have 6000 miles on my truck and it has gotten so much more powerful than it was day one. my friend has 20k on his 6.4l and his will take mine in a race. Its a tight motor that needs breakin.
Also you dont feel the 6.4 power through the suspension. its so smooth you have to watch the speedo to see whats going on.
I hated the 6.7l. The dmax was very nice. I like the 6.4l tho
