Drain Tranny Fluid or Fluid Exchange?
Old Nov 20, 2008 | 07:43 AM
BAJA MAN's Avatar
I had my tranny fluid serviced (drained and re-filled) at 30K. I am at 64K now and am trying to decide on whether to drain and refill again or have the fluid exchange done. I wil have dealer do work.
What are pros/cons of each method?
I've heard of an exchange system that removes fluid, filters it, and returns it to tranny. I believe dealer uses this method. Is this correct? Old fluid is old fluid, regardless if it is filtered.
Tranny appears to shift fine - once in a while it will hunt back and forth 1-2-1 at slow speeds-usually slow speeds uphill. Do I need band adjustments? Does dealer adjust bands during normal tranny service?
I've also read here on this forum to NOT adjust bands. Why
or
Should I have tranny fluid drained, filter changed and bands adjusted.
Thanks!
dundun98
Nov 21, 2010 11:50 AM
nvr-enuf
Apr 30, 2010 08:41 AM
bek
Jan 29, 2007 10:51 PM
hotdram
Sep 9, 2005 09:40 AM
