Different EGR question
Old Jul 2, 2009 | 10:13 PM
nolo263's Avatar
Alot of people have unplugged the egr with great results. My question is concerning the "you lose power comments". Has anyone uplugged the egr at the track to test the difference in 1/4 mile times. This would tell you definately if you lose power.
Please share your experience..
Thanks
Old Jul 2, 2009 | 10:53 PM
nolo263's Avatar
Ok I unplugged my egr, check engine light came on, then I hit high idle and the red thunderbolt came on why???
Old Jul 2, 2009 | 10:59 PM
Lil Dog's Avatar
Do you have the latest flash to the ECM?
Old Jul 2, 2009 | 11:01 PM
nolo263's Avatar
It is a 09 what is the latest flash? My truck was built in 12/08.
Old Jul 2, 2009 | 11:04 PM
Lil Dog's Avatar
Not sure for the 09 Software.. I would have to check.. Hmm..
nolo263's Avatar
It seemed fine till I used the high idle to warm it up..
Old Jul 3, 2009 | 05:59 AM
Blake Clark's Avatar
Mine will do the same thing, If the egr is unplugged and I use the high idle, the throttle light will come on and itll will start stumbling and when you let off the accelerator sounds funny when "decelerating".
No clue why, but to get it to act right, I have to plug in the egr and run it for a while and then I can unplug it again.
Old Jul 3, 2009 | 10:44 AM
nolo263's Avatar
Thanks So if the egr is unplugged you cannot use the high idle? I wonder if everyone has the same problem..
Old Jul 3, 2009 | 11:41 AM
Lil Dog's Avatar
I never had an issue with it unplugged.
Old Jul 3, 2009 | 12:47 PM
Tree DR's Avatar
I have the cross over tube pluged on mine and leave the egr pluged in so I don't get any codes from it. As to stock power on a dyno I saw 3hp more with the egr unpluged even though the crossover was pluged. My truck is a Chassis Cab so it probably won't be the same for the regular pickups.
Old Jul 18, 2009 | 01:09 AM
pln4472's Avatar
Tree DR,
I have been told that just pluging the cross over tube will throw a code. because of the test for different pressure.
How did you plug it?
Thanks
Marlin
Fisherguy
29
Aug 6, 2009 12:45 PM
MOJO1
Aug 4, 2009 06:28 PM
Dave88LX
Dec 8, 2006 02:53 PM
andyr354
Aug 15, 2006 11:05 AM
