correct 4x4 operation?
Old Aug 21, 2010 | 09:35 AM
tallboytx's Avatar
Howdy Ya'll, I am new to this forum and to Dodge trucks and 4x4's. My 08 SLT has only 4200 miles and is mostly a garage queen because I work overseas. What is the correct way to use the 4x4 control on the dash? 4 Lock seems to work fine and all 4 will lock and dig. When in 4 Low the front axle does not dig. Is this a normal differential type of operation in 4 Low or is something wrong here? Thanks
Old Aug 21, 2010 | 09:56 AM
Blake Clark's Avatar
Welcome to the DTR!
4 Lock is just the old 4 High
4 Low is well, 4 Low
The front axle should behave the same in 4 Lock/Low other than the gearing being different.
Old Aug 21, 2010 | 10:10 AM
tallboytx's Avatar
Thanks very much Blake and I am looking forward to learning a lot on this forum.
Old Aug 21, 2010 | 04:15 PM
BroncoAZ's Avatar
In 4lo the front wheels are likely not being spun fast enough to dig like in 4lock, but you would notice them spinning if you got it stuck.
Old Aug 21, 2010 | 11:18 PM
dodge_kid9712's Avatar
been stuck in mine in 4 low got out of the truck in 4 low in drive and took a vid of all 4 wheels just spinning same speed all round not going anywhere not even going deeper
Old Aug 22, 2010 | 09:48 AM
46mech's Avatar
Since we're on the topic...
I'm putting this out to you guys who get to use their trucks in the snow. Going thru a foot or more of snow....... 4hi or 4low? I've not had a 4x in the snow before living here in SD, but this past winter I had an occasion or two to go thru some deep stuff. I used 4hi and got thru it, but noticed it didn't take long to get the water temp up. Thanks
Old Aug 23, 2010 | 08:48 AM
beardedone's Avatar
I always use 4 high. I have only used low once and it was for pulling out a small stump.
Old Aug 23, 2010 | 10:38 AM
CamperAndy's Avatar
Is the 4 lo lite on solid or blinking? 4 lo is tough to get into sometimes so you may not have actually been all the way into 4 lo.
Old Aug 23, 2010 | 08:42 PM
46mech's Avatar
Well, I know that if the 4low light is blinking it means the xfer case is not locked into gear. I've found that to shift into 4low completely, I have to stop the truck completely.... and either shift into neutral or park, I can't remember which.
Old Aug 23, 2010 | 09:37 PM
KWKING's Avatar
Should be in neutral and rolling ever so slightly,less than a walk for 4 lo.
kingofdodge7131
13
Nov 20, 2010 05:45 AM
truckbouy2
Mar 29, 2008 10:48 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
