clutch - power surge?
Old Feb 25, 2008 | 10:06 PM
f272272's Avatar
I have an 07 6.7 6 speed manual 1 ton fwd dually cab chassis. At about 1800 rpm if I give it half throttle or more it revs real quick to 2300 like the tires are spinning or like I pushed in the clutch while giving it gas. It does not matter what gear I am in. It reminds me of my mx days when I would pull the clutch it while on the throttle to keep the motor from bogging. The truck has 32,500 miles. Any idea on the warranty timeline. I also have a major electrical issue that is messing up my rear lights.
Thank you.
Old Feb 25, 2008 | 10:17 PM
Spooler's Avatar
Sounds like your clutch is slipping bad. Warranty is for 12,000 miles. Maybe you can conveince them of a bad pressure plate and cover it under warranty. Pay for the clutch disk, through out bearing, and pilot bearing. Or, you could just get a South Bend OFE and flywheel, call it a day and be done with it.
Old Feb 25, 2008 | 10:22 PM
f272272's Avatar
What about warranty on the electrical problem?
Thanks for the info
Old Feb 26, 2008 | 10:29 AM
Spooler's Avatar
I don't know on the electrical issue.
Old Feb 26, 2008 | 05:07 PM
f272272's Avatar
does this clutch slipping diagnosis sound correct to everyone else. thanks for the info spooler.
Old Feb 26, 2008 | 10:45 PM
f272272's Avatar
I forgot to mention I have 19.5's. Should that cause early clutch failure?
SpinEmNSmokeEm
Jan 2, 2008 04:23 PM
dieselnewbie
Nov 8, 2007 06:46 PM
JohanBolle
Jun 26, 2007 12:01 AM
coolslice
Nov 9, 2004 07:13 AM
