Clunk when going into park and shudder when towing from a stop...
Old Aug 30, 2014 | 11:38 PM
Scotty's Avatar
Top's Younger Twin
I'm guessing my carrier/center bearing and the front u joint on rear shafts that has play are the culprits.
There's slight play in the center bearing and I can move the first rear driveshaft left/right a fair bit with noticeable play in the forward u joint. Everything else is tight.
Anything else I should check?
Not bad mileage on those parts. Right around 180-200k on this set.
Thought about a single shaft replacement. Might be a hassle with it being stretched.
The clunk from drive or reverse to park is getting louder.
nvr-enuf
13
Oct 25, 2010 12:35 PM
Cummins610
17
May 29, 2010 12:50 AM
MasseyMan1089
May 23, 2007 07:56 PM
JohnnyH
Feb 28, 2006 10:44 PM
Nuttymopar
13
Dec 8, 2005 10:21 PM
