Changing The Fuel Filter
Old Mar 30, 2010 | 10:10 PM
EverydayDiesel's Avatar
Search is broke right now
I just got my truck (33k miles) and I probably should change the oil and the fuel filter.
Where is the fuel filter located on this truck (2007 6.7) and what is the procedure for changing it?
Old Mar 31, 2010 | 04:15 AM
PRSKILLER's Avatar
Here is a good write up from TDR.
http://www.turbodieselregister.com/f...el-filter.html
I just got mines from Genos and will be changing it this week.
http://www.genosgarage.com/prodinfo.asp?number=FS43257
Old Mar 31, 2010 | 10:40 AM
coolbreeze's Avatar
The fuel filter is on the driver's side. There should be a a clear 3/8" ID clear drain tube attached to the bottom. I recommend buying a longer length of clear tubing to make draining easy and clean. A gallon zip-lock bag over the filter when you unscrew the old one will help contain any fuel that didn't drain. Good luck.
Old Mar 31, 2010 | 11:41 AM
geeez....37 bucks for a fuel filter!
http://www.genosgarage.com/prodinfo.asp?number=FS43258
Old Mar 31, 2010 | 02:04 PM
klx650a2's Avatar
Just wait till you need to replace the CCV filter, up here the dealer wanted $178.00 (just for the filter, labour was another $100.00), I paid $72 at the Cummins dealer and did it myself. The transmission filters were 78.00, only available at the dodge dealer...
I still love the grunt of the 6.7 and that 6 speed auto with engine brake....
flinn101
Dec 31, 2005 06:55 PM
kajngrl
Mar 8, 2005 11:08 PM
faurotus
14
Feb 27, 2005 11:40 AM
Slice
13
Jul 23, 2004 06:07 AM
debolton
24
Jun 29, 2004 09:22 PM
