CEL light
Old Aug 28, 2007 | 01:54 AM
Bigwhitey3500's Avatar
CEL light
Woohoo! My truck thru the check engine light @ 3190 miles. I feel like part of the family now. I'll call the dealer in the morning. I tried the 3 on/off key trick for the codes and nothing. I have the odo in "trip" mode. Any other tricks to this?
Old Aug 28, 2007 | 02:05 AM
skeeterboy's Avatar
My cel light has been on 3 times for about 50 to 75 miles at a time. My truck has 4200 miles on it.
I never took it to the dealer and the light seems to go away not long after it comes on.
I did call the dealer and they said most likely their is a sensor in the exhaust that gets sooted up and takes a while to clean off.
My wife thinks it is because I am filling up with diesel with the truck running and the computer is getting confused. Go figure.
Let us know what the dealer tells you.
Old Aug 28, 2007 | 10:29 AM
areddy's Avatar
on mine you set the emergency brake before you turn key 3 times and it works. I think a lot of people are still putting the wrong fuel in on other forums i have read some people think that ulsd is an option. www.allpar.com is a good site if you want to keep on dodge
Old Aug 28, 2007 | 12:26 PM
Hired Gun's Avatar
Just because it comes on does not mean it has anything to do with a sensor in the exhaust. Mine caome on as a vane problem with the turbo. Next time it happens they are putting a new turbo on the truck.
Old Aug 29, 2007 | 01:54 AM
Well, today the light is off. Haven't called the dealer yet. I guess I'll just wait and see what happens.
Old Aug 29, 2007 | 03:13 AM
skeeterboy's Avatar
I just ran out to my truck and did the on / off / on / off / on / off / on trick and the odometer dashed out for 10 seconds and it said done.
I am assuming it would of thrown a code if there was one and I may be having the so called ghost code issue I have been reading about.
My CEL comes on for about 50 / 75 miles then goes away for awhile. System OK and truck runs fine....
Hope this helps....
Old Aug 29, 2007 | 08:54 AM
Rrloren's Avatar
Skeeter , you may have the dreaded p245a code. Mine gets it and doesn't show using the key method. I have a scanner and it shows there.You may want to get to the Dealer and let them deal with it.
Old Aug 29, 2007 | 09:54 AM
2rowdy's Avatar
My p245a code came up again this morning (third time). I just stopped by dealer to let him know and tried to wait on tech but he was late and I had another appiontment elsewhere. When I left cel was off and code was gone so I am just going to keep driving this time untill something happens again.
MrSuzuki
Jun 16, 2009 12:23 AM
boaterman
Oct 15, 2008 10:44 AM
Hillbilly Delux
Mar 20, 2008 05:01 PM
hotmod660
Jul 12, 2006 03:23 PM
