Can I change my rear end?
Old Jul 30, 2009 | 08:09 PM
Volunteer1968's Avatar
I have a 2008 Cummins Mega Cab. How much is involved in changing my rear end to a 4:10?
Thanks
Old Jul 31, 2009 | 05:59 AM
tesla440's Avatar
Beside completely removing all of the fliud, axles, ring & pinion, install ring & pinion, set back lash & install rest of parts.
Not bad.
I would make sure that you have the the dial indicator & marking grease handy to do the job right.
If you have never done anything like this, plan on 6 or so hours so that you don't have to rush yourself & you're able to follow the directions as you go.
It's not difficult, it just takes time to do it right.
If you have a 4x4 you will also have to the front as well.
Old Jul 31, 2009 | 09:48 AM
Thanks for your answer....
I'm sure that job is far beyond my technical capability - besides I don't have a place or the tools to attempt it. Will a Dodge dealer do the change or should I take my truck to a good garage? Any idea how much this should cost?
Old Aug 7, 2009 | 09:45 PM
RAMBOSS's Avatar
What Gears do you have currently? is your truck 4 x 4. With state are you in?
Old Aug 22, 2009 | 10:37 PM
redruM Hauler's Avatar
gears and install kit will run you 350 +/- labor 250-300 here in dallas
Totallyrad
Jul 19, 2011 07:41 AM
doorguy
Jun 8, 2007 06:19 AM
ouchman
Apr 16, 2006 03:26 PM
gdh11
Nov 14, 2003 09:51 AM
