Buzzing sound in dash
Old Nov 3, 2007 | 11:56 AM
Rocky MTN RAM's Avatar
Has anyone else experienced a strange BUZZ from the gauge cluster area of the dash?
It is very annoying!!!!!!
It starts when you are at low RPM's and under light throttle ( ie. 5th or 6th gear at low MPH's).
When it first started it almost sounded like an electrical buzzer of some type.
I thought maybe it was coming from the A-Pillar where my EGT gauge is installed, but I can't trace it to that.
I have a friend with a 5.9, no EGT gauge and he is having the same problem.
If anyone has dealt with this and has a fix I would really appreciate some information.
Old Nov 3, 2007 | 12:35 PM
dtenorio's Avatar
I had a buzzing sound which I thought was comming from the dashboad or drivers window. Turned out to be a plastic disc like cover under the driver side mirror. Look under your side mirror and you'll see what I talking about, I think it's an access cover. When you find it, try driving with your window down and place your hand under the disc. If the noise stops, you can put a little caulking in the groove to keep it from vibrating. I hope this helps, I know the buzzing sound was driving me crazy too!
Dan
Old Nov 3, 2007 | 01:00 PM
Thanks for the advice.
This noise is definetely coming from the dash area inside the cab.
I appreciate your input though.
redneck_racer
Nov 18, 2008 06:48 PM
Onemoparnut
Sep 8, 2008 08:32 PM
Thundercloud
Oct 25, 2006 02:24 PM
alltimelow1
Oct 4, 2006 06:07 PM
KTM rider
Apr 7, 2005 03:35 AM
