Bigger Tires......Speedometer???
Old May 5, 2009 | 10:00 PM
akfireman's Avatar
I just put 315/70/17s on my truck...... what do I need to do so the Speedo is correct?
Old May 5, 2009 | 10:43 PM
truckjunkie's Avatar
First, fill out your signature so everyone knows what year, etc. truck you have.
Second, use the 'search' function available on this forum. There's a lot of information about recalibrating the speedometers, and how it can be done via a Snap-On reader tool, a Smarty Jr., or the dealership.
Old May 6, 2009 | 10:13 PM
akfireman's Avatar
Sorry new to this. I am not even sure how to fill the signature out..lol
Old May 7, 2009 | 10:09 PM
tnhtractors's Avatar
if your running 315/70/17 then you are going 5 mph faster than what speedometer says. 35 mph on meter means 40 mph actual speed. I'am running 317/70/17 right now
Old May 14, 2009 | 12:04 PM
driftingfly's Avatar
Bully Dog makes a Speedometer Calibration & Diagnostic Tool. Contact your local Off-Road Shop, It cost me around $100.00. You can also purchase the tool for $640.00 at http://www.xtremediesel.com/bullydog...ostictool.aspx
The Speedometer Calibration & Diagnostic Tool serves two functions:
- Calibrate the OEM in dash speedometer to read correctly with the addition of a larger or smaller diameter aftermarket tire size.
- Read and erase diagnostic trouble codes that appear in vehicles computer when the vehicle has a problem.
Using this tool is simple, it can be operated by anyone who has a general knowledge of tire sizes. To calibrate an OEM speedometer.
1. Plug the OBD II plug into a vehicles OBD II port.
2. Select the correct vehicle application.
3. Enter in the new vehicle tire size.
The whole process takes less than five minutes per vehicle.
ADJUST TO A LARGE RANGE OF TIRE SIZES:
When going up in size the Speedometer Calibration Tool can calibrate for a maximum size of 38" tire diameter. When going down in size it can accommodate for a 26" tire diameter.
Old May 15, 2009 | 09:42 AM
boatpuller's Avatar
you can also take it to the dealer to be recalibrated.they did my 02 for free about 5yrs ago.but,they charged me a 1/2 labor to have it done on my 09.nothings free around chrysler anymore.
Old May 16, 2009 | 09:30 AM
jerry007's Avatar
If you have a good service manager like I have, he or she will do most anything to your ECM that you ask. My dealer service manager personally plugged in my truck the day I purchased it and did all sorts of things that I had requested. Did not cost me anything. He let me watch him and even showed me what he was doing. My 2cents worth.
May 29, 2009 10:24 PM
R & A Equipment
Feb 26, 2007 11:27 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
goin
Aug 8, 2003 05:14 PM
