ball joints (how much play is acceptable)
Old Jan 14, 2009 | 09:20 AM
bluesurf's Avatar
my ball joints are clanking now for 10k. every time i hit a bump they rattle pretty well. so i bring truck in for warranty and they tell me thay are in spec. go figure. i get what seems to be a 1/2" play when i use a tire iron and lift tire. question is if i fail inspection will they then have to warranty them? thanks
Old Jan 14, 2009 | 04:33 PM
Hannibal's Avatar
You sure it's the ball joints you're hearing? My hood rattles and I have to adjust the cheap plastic stops on the radiator cross member to tighten it up every now and then. I about went nuts trying to figure out what the clunking, popping and creaking was. It sounded just like ball joints. Your joints may have play in them but, check you hood. It may be the source of the noise.
Old Jan 14, 2009 | 05:36 PM
bluesurf's Avatar
good idea but i know it is the ball joints. i spent days tightening things and lubing this and that. i lifted the truck and used a tire iron and actually replicated the clunking noise.
CZSteve
Jun 28, 2011 11:11 PM
bcfreighttrain
Aug 5, 2009 07:00 AM
PapaPerk
Apr 16, 2005 04:19 AM
Fishbait
May 18, 2004 09:39 AM
