6.7 Leaky CP3
Old Feb 20, 2008 | 09:34 PM
DodgeCowboy's Avatar
DTR's Cow Boss
6.7 Leaky CP3
Does any one know if the 6.7 had a problem with the cp3? dads noticed too night he has a weep on the driver side behind the tire looks like were the pump might be i think? truck has 4000 miles on it he is going too take it in for his service and see what they say
Old Feb 21, 2008 | 06:37 AM
coolbreeze's Avatar
He should crawl under and check his fuel filter for leaks.
Old Feb 22, 2008 | 08:36 AM
truckjunkie's Avatar
Wow - I would've hoped Dodge/Cummins finally figured out that the Bosch CP3 design was causing leaks, especially in cold climates, by now...
Has it been really cold in your neck of the woods? Do a search on this thread for CP3 leaking and you'll find all kinds of stuff.
I had mine replaced a couple of years ago with (I'm guessing) a rebuilt one with the correct seals. I haven't had (knock on wood) a leak since.
Old Mar 2, 2008 | 02:23 PM
canadiandiesel's Avatar
we hit -49 here this winter and no problems, the only thing is after -40 the overhead does not want to read that low, guess that means i should have stayed in bed
Old Mar 11, 2008 | 11:40 PM
DTR's Cow Boss
Found it. Master cylinder leak dealer replacing master tomorrow
RussianVolk
Jun 29, 2010 01:13 AM
dodgediesel
Dec 23, 2008 11:53 AM
rallydriver
17
Dec 21, 2008 10:01 PM
na4now
Jan 6, 2008 11:53 AM
hotmopr
Jun 29, 2006 10:22 PM
