6.7 EGT levels
Old May 16, 2008 | 08:57 PM
Pirate's Avatar
I expect to be questioned about it but since I don't have and never have had a chip or programmer on it I'm not concerned.
Old May 18, 2008 | 01:06 PM
titoheadfaceman's Avatar
Originally Posted by BroncoHound
the DPF, when in regen, will kick the EGT's over 1400 degrees so i would say 1550-1600 would probably be the MAX safe temp...
if you hit 1500 degrees then you just more than likely cracked your DPF. If you start seeing 1300 degrees, even during regen, then you might be seeing an engine problem. Maybe an injector leaking or something like that. You will usually see temps of about 1000 to 1100 degrees. Like I said, 1500 degrees is WAY too high.
Old May 18, 2008 | 02:17 PM
BroncoHound's Avatar
Incorrect. There have been guys that have hit 1800 degrees racing these new 6.7s. Lots of testimonials of 1600-1700 degrees when pulling heavy. I won't worry about EGT's unless I see upwards of 1600 when in regen.
svanni
16
May 22, 2007 12:37 PM
yannick
Apr 26, 2004 03:38 PM
NC_Mog
Jun 11, 2003 09:27 PM
brassbuldog
Apr 22, 2003 09:06 PM
steelsoldiers
Jan 3, 2003 09:46 AM
