dually rim questions
i have a 2008 dodge ram 3500 mega cab and am lookin are getting some rims.. my questions are.. what is the 1.stock offset 2.stock blot pattern 3.diameter 4. width...a lot of peopel are just buying the outside 4 rims and running the stock ones on the inside of the dualls..is that ok? any info will be a great help!
thanks
thanks
not sure of the off set but the bolt pattern is 8 on 6 1/2 and the diameter is 17" wheel and i think the width is either 6 or 6 1/2 " and as far a running the stock inside wheel that is how you have to do it from what i have been told from the place i was going to buy wheels from. Also the problem with buying wheels is you won't be able to inter change the backs wheels with the front wheels so when it is time to rotate the tires everything has to dismounted and then remounted on the wheels.
Kinda funny how you give some one the answers to their questions and then you never hear anything back from them( IE: like a thank you or hey that was what i was looking for.) come on people have a little common courtesy is that to much to ask for
We could start by getting rid of the two party system in washington to rid the self-absorbed folks there then trickle down. Why people look up there for help is scary in a way! Ok, I am done.
