4 Wheel Drive
4 Wheel Drive
My 4 wheel drive makes some grinding chattering noises only when in 4 wheel drive not 2 wheel drive. Transfer case is fine. When I took off the front diff cover It seem like the Pass. side axle shaft has a very little slop inside the gear. Where can I find the parts to fix the front end or how do I diagnose the exact parts that need replaced.
Thanks for all your help
Better take a look at the chain inside the case!!! You won't hear any noise out of it in 2wd but 4wd is a different story.....seen this happen several times.
Sent from my high tech squawk box
L.J.B.
Jun 27, 2014 10:21 AM
roxxx
Apr 13, 2009 05:15 PM
04ctd
Dec 7, 2007 08:19 PM
gman2310
Sep 27, 2006 12:08 AM
